W skrócie - zamiast zwykłych nakrętek na wentyl zakłada się takie z pomiarem ciśnienia. W przypadku gdy ciśnienie w oponie jest za duże/małe wentylek zabarwia się.
http://www.youtube.com/watch?v=LNkxJHyl ... mt=18&t=39
zakup grupowy?
Creator John Milanovich on Feb 16
Thank you Shadow for your kind wishes and your continued support! We really value it.
Marc - thank you! Yes. We have had great luck with our accuracy and can get it within 1PSI. As far as color interpretation, there is some color indication as your tire loses air and with some psi levels, you might see a orange sliver as psi level drops even 1 to 2 psi. However, it really POPs and the band is all orange at 20% low. It is a degree of noticing it. You can certainly see the color 20 feet away when it is fully engaged as low. I understand the point though and with our Layar packaging we can probably put something in the installation video about this. Great thought.
Skyluker pisze:Trafiłem na projekt w kickstarterze, który może niektórych zainteresować.
zakup grupowy?
Skyluker pisze:z tego co pisze szefu kolor pojawia się już po zmianie +/- 0.1 bara. Pełne wybrawienie wentyla to +/-20% czyli jakieś 0.4 bara.
