SPS Motorsport
English speaking subforum for MX-5/ MIATA users all around the world. Please, english language only.
Guido@SPS
01 lis 2019, 12:24
That's true. Would be a great combination. ;)
TerminatorPi
01 lis 2019, 13:34
Omg. I love the color. I wish it was one of the factory ones. I'd definitely go for it instead of red. And with a tan interior...
Koza team member!
Guido@SPS
01 lis 2019, 15:38
Haha, I see there are some fans for that color with tan interior. :D
mike_d
Wersja: SkyFreedom Karai
02 lis 2019, 21:32
There's no miata like green miata :D
Quick question - is there any sane way of attaching front license plate to that grille?
Guido@SPS
04 lis 2019, 20:02
Hey mike_d,
not really. We use our own license plate mountings made of plastic and attach them to the grill. Then we mount the plates on the mounting.
Guido@SPS
04 lis 2019, 20:03
3 weeks ago we took part at the German TimeAttack Finals and the European TimeAttack at the Nürburgring. Our race cars performed well, but our red ND just got a little accident. Nevertheless we celebrated many victories in different classes. It was a great season ending!
Best regards
Guido from SPS
mike_d
05 lis 2019, 16:14
Guido@SPS pisze:
04 lis 2019, 20:02
Hey mike_d,
Can you please share photo of that mounting? What I'm interested in is way to quickly mount/detach entire mounting with license plate from non-OEM grille.
Guido@SPS
13 lis 2019, 14:41
It is a simple solution. We just mount the plastic mounting with some screws, nuts and washers. Nothing special.
Guido@SPS
19 lis 2019, 15:25
Long time nothing new here. So there You get a cool customer project. ;)
This 1.6L Miata import got a turbo conversion and has still its air conditioning installed and running. The engine got forged parts and the turbo is an upgraded TD04 turbocharger. Now the engine produces 281hp at the flywheel and 362Nm/267lbft torque.
The specs:
- 1.6L B6 engine bored to 79mm
- JE pistons 79mm
- Cometic head gasket 79mm
- Molnar Technologies conrods
- ACL main bearings
- King conrod bearings
- Upgrade TD04 turbocharger
- SPS 700ccm fuel injectors
- SPS engine oil cooling kit
- Competition Clutch Stage 3
- BC Racing BR-series coilover
- Fender Flares
- Japan Racing JR19 8Jx15 0mm offset with 20mm spacers front and 25mm spacers rear
- Nankang NS-2R 195/50 R15 tires
Best regards
Guido from SPS
Guido@SPS
13 gru 2019, 16:28
Here You can see a really serious project.
This NC is getting a Borg Warner EFR7163 turbocharger on a forged engine running with 1.3 bar boost tuned with a MS3. It will produce around 400hp at the flywheel with 455Nm/336lbft torque.
It also gets a full roll cage, fender flares, gearbox oil cooling system and differential oil cooling system.
Best regards
Guido from SPS
Guido@SPS
21 sty 2020, 9:44
Hello guys,
the first post in 2020, this time something special.
We also restore complete cars. The customer made the decision to restore his car completely from zero to the top.
It gets a new painting, new seals, new gaskets, new rubbers, a new windshield, a rollbar, Lotus Elise seats, a turboconversion (Borg Warner EFR 6758), a SPS coilover setup, and some nice wheels and tires.
We are filming the whole process and creating a time lapse video.
Best regards
Guido from SPS
Guido@SPS
07 lut 2020, 16:25
Some progress is going on. ;)
Best regards
Guido from SPS
mike_d
07 lut 2020, 18:57
Damn that's clean <3
Guido@SPS
27 lut 2020, 8:13
Some days ago we had a really nice looking ND here. We mounted Rota Kyusha 9x17" with 20mm offset on Hankook Ventus V12 215/40 ZR17. The suspension is our SPS "Super Low" coilover setup. The last step was mounting an ATH exhaust.
Best regards
Guido from SPS
Guido@SPS
29 lut 2020, 16:42
Here we have a new ND completely customized and wrapped in british racing green. The customer bought the new car from our Mazda dealer partner and we customized it.
Specs:
2020 MX-5 ND 184hp
SPS street coilover setup
Rays TE37 8x16" 25mm offset on 205/50 R15 Federal 595 RS-R
Stoptech Big Brake Kit
Recaro Pole Position
Customized steering wheel
Full exhaust with racing header and HJS 200 cells catalytic converter
Best regards
Guido from SPS
TerminatorPi
29 lut 2020, 19:02
:slinotok:
Love the color. If only Mazda offered ND in this color, I wouldn't have bought a red one :D
Koza team member!
mike_d
01 mar 2020, 12:17
Looks awesome (especially with door internals also wrapped)! Now imagine wooden steering wheel and gear knob on top of that BRG :)
Say, how have you dealt with pedestrian protection system activators when mounting spyder grille?
Guido@SPS
02 mar 2020, 8:35
Hi mike_d
yes we did, we changed the way it's mounted to have everything in OEM Function
Guido@SPS
02 mar 2020, 16:54
And again a really nice ND. This time we installed BBR GTi camshafts with a full exhaust system and tuned the ECU on the dyno. Now car the has 200hp at the flywheel instead of 160hp.
The car also got some nice 17" Rotas, our SPS street coilover setup and Recaro pole position in full leather.
Best regards
Guido from SPS
Guido@SPS
26 mar 2020, 10:35
Hey guys,
we have a special offer for You.
We sell our TD04-Turbokit for the MX-5/Miata NA, NB and NBFL for just 3499€.
On the stock 1.6L You get 220hp at the flywheel, on the stock 1.8L You get 250hp at the flywheel.
The kit contains:
Kraken cast iron manifold
Two-piece downpipe (first part made of cast iron, second part made of stainless steel)
Turbocharger incl. Matching connection accessories
Steelflex oil feed pipe
water pipe
High temperature oil return
Giselwerks Hardpipe boost pressure piping
efficient intercooler
Open air filter
SPS Motorsport 700CC Injectors (calibrated and tested)
Engine control unit with matching basemap
mounting material (incl. spark plugs BKR7EIX and modified washer fluid reservoir)
https://www.youtube.com/watch?v=v18XYMgpjmU&t=0s
https://sps-motorsportshop.com/shop/en/ ... 98-SPECIAL
Best regards
Guido from SPS
pirul
Moderator techniczny
Wersja: RX-7 FB2 '83
26 mar 2020, 11:49
Hey Guido, we're vulnerable right now and prone to unreasonable decisions, that's not fair, stop it! :lol:
Guido@SPS
26 mar 2020, 11:55
:D :D
Guido@SPS
29 kwie 2020, 8:13
One of our bigger projects this year:
This MX-5 ND G184 gets a full engine swap to a 3.7L V6 LFX Camaro engine with transmission. And we use the car to develop a safety rollbar for the MX-5 ND, also to attache 4-point-harnesses.
Best regards
Guido from SPS
Wersja: Magic
29 kwie 2020, 10:33
That sounds impressive!
Guido@SPS
14 maja 2020, 7:51
Hey guys,
here we have e really clean an nice looking NA with a Borg Warner EFR6258 turbo conversion on a stock 1.8L BP making 250hp. Also a very cool detail, the 7x14" Enkei RPF1 with 185/60 R14 Nankang NS-2R.
Specs:
- 1.8L BP with EFR6258
- ME221 ECU
- 3" exhaust system
- Enkei RPF1 7x14" 28mm offset with Nankang NS-2R 185/60 R14.
- Xtreme Clutch Stage 1
- BC Racing BR Series coilover setup
- Mishimoto performance radiator
- Sparco Sanremo steering wheel
Best regards
Guido from SPS
Guido@SPS
16 maja 2020, 8:08
This is a really nice equipped MX-5 NC 2.0L. The car got some Recaro Pole Position mounted on our new developed seat brackets in combination with our new roll bar for the MX-5 NC and a 4-point harness. The car also got our SPS coilover setup, H&R anti-roll-bars, 17" OZ Ultraleggeras with Nankang NS-2R, a CarbonMiata Ducktail and a CAE Ultra Shifter.
Best regards
Guido from SPS
waran
16 maja 2020, 10:26
Ubi bene, ibi patria
Guido@SPS
24 lip 2020, 10:05
Hey folks,
the last post was a few weeks ago. Now I have something new for You.
As You may know not only our customers drive MX-5s/Miatas, also some of our employees have them.
This is the car from our professional for all body work. It got a full Carbonmiata widebody kit which he installed by himself. The car also has a TD04 turbo conversion on its 1.8L BP making 250hp at the flywheel. To get the wheels (10,5x15 -13mm offset) fitted under the fenders he also installed camber arms on the rear axle together with our own SPS Super Low coilover setup. In the interior he installed a pair of Bride Low Maxx seats.
Best regards
Guido from SPS
torzech
Wersja: '90
16 sie 2020, 10:31
Guido@SPS
25 lis 2021, 10:50
Hey guys,
i hope it is ok that i do a little advertisement.
Tomorrow we have Black Friday and we have several new products in our shop. All of them will have a 12% discount on this day.
Our new turboconversions, ITB conversions, Duratec conversions, etc. and also many other products come with a TÜV certificate, so maybe there is something interesting for You.
If You have questions, just write here or write me an email on guido.sikora@sps-motorsport.com
